zoom selected all viewports suddenly is working only for top and perspective views, not for other viewports.
top
perspective
See video recording in this link
3dm file producing the problem is attached here, too.
Rhino_issue_geom_dissapear_&_unable_to_zoom_to_selected__v001.3dm (520.9 KB)
Searching the forum didn’t yield any solution.
Hi - When you make the Front or Right view active and open the Properties panel, you will see that the Distance to Target is, well…, rather large. Somehow, these viewports became corrupt. You can fix this by running the 4View command. -wim
Front
Right
Properties
Distance to Target
4View
Thanks a lot, @wim. Your solution works.
Seems that we need to run 4View when the problematic viewport is active to solve its “corruption”.
