Added note 6/27/2024 I find that the zooming doesn’t stop, but becomes very very little at a time. The visual effect is that zoom doesn’t work. It is worse if you select the vertical element in the view. It extends the farthest beyond the visible region. Hope this helps.
I’ve had this problem before. When I select some object, I cannot zoom until I de-select the object. Until now I couldn’t isolate it enough. But in this simple file, in perspective view, if I select an object that goes beyond the viewport, I can’t zoom. If I select an object contained wholly within view, I can zoom. It’s a bit maddening. Hope somebody can fix this. I never had this issue with Rhino7 as far as I can remember. Here’s a pic of how the viewport should look when you open the file.
here’s the file
EW-main-hinge-study-262406.3dm (526.7 KB)
here’s my system info
Rhino 8 SR9 2024-6-19 (Rhino 8, 8.9.24171.03001, Git hash:master @ c7bc7dce8c2b456b3f0c5f0fa669295aa802ef1a)
License type: Commercial, build 2024-06-19
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 8GB)
.NET 7.0.12
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-13-2023 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P600 (NVidia) Memory: 4GB, Driver date: 3-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.49
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-14-2024
Driver Version: 31.0.15.3849
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24171.3001
