Currently I have a problem with creating new material or editing existing material on material editors.
Even if it is a simple color material it doesn’t save up so now I can only use the materials that’s been saved previously.
Can anyone know what’s the caused to this problem?
My colleague seems to have the same issues.
We’re using Rhinoceros 5.5.3 for Mac and we don’t use any other plug-ins.
And it happens with my colleague since the first time she purchased the license.
Unable to create materials, even if it’s just a simple color coded material without importing any images we still can’t save and use the material.
Because usually after we create the material there would be a pop up message saying “would you like to save …”, but now it doesn’t show anymore.
Can you provide us with detailed steps to reproduce what you are seeing? Sometimes the devil is in the details.
It might also be helpful to give us some more System Information. Navigate to Rhinoceros > About Rhinoceros > More Info > Copy to clipboard and please paste the results back in here.
Thank you @chichi.tjandra for the detailed steps. That is exactly what I needed.
Ugh. That is a bug. This appears to be a regression in the 5.5 update to Rhino 5 for Mac. (This bug is not present in version 5.4.2). This needs further investigation.
There is a work-around…
Drag your custom material from the Library panel on the left-hand side, into the Model Materials panel on the right-hand side.
Select and edit your custom material in the material editor panel below.
When you are done, you can drag this material back to the Library on the left and your customizations should stick.
Sorry about this bug and thank you for reporting it. Logged in MR-3265.
