Rhino 5.0 64-bit - Crash when creating a new material
Hi there,
I’m experiencing a strange issue with Rhino 5 64 bit on Windows 10.
PC and Software specs:
Version 5 SR14 64-bit
(5.14.522.8390, 22/05/2017)
_Commercial _
Windows 10
GeForce GTX 1080 (latest driver update)
I’m working with Rhinoceros 8 hours a day so I know how it behave and what are the limitations, this is the first time it happens.
I proceeded like this:
  • Applied (as usual) a TIF (11 MB - 1270 dpi - 3350*3350 px) texture to a small mesh cylinder;
  • Rendered mode works like expected;
  • All was fine.
  • Closed file;
  • Reopened;
  • Click on “Material Editor” tab to show the list of the existing materials (only 1) in the file;
  • Rhino can’t load the material list and freezes without any errors so I have to force close.
So before closing and reopening file was working as expected.
I can’t figure out what the problem is.
Some interesting facts:
  • Rhino crashes also when I’m creating a new White Matte.rmtl in a completely new blank document.
  • Tried to restart PC with no luck.
  • _RefreshAllTextures command with no luck.
  • Using the 32-bit version all works fine, I can open the same file, copy and paste the same mesh cylinder into a new blank document, apply the same TIF texture without any problems.
  • I’m usually working with much larger TIF files so I think the issue is not RAM or GPU.
  • Same problem as this guy: Rhino 5 crashing when trying to edit material
  • No plugins installed
Any thoughts?
Thanks for the help,
Julio :grinning:
Hi Julio - thanks, I’m checking on this - I do not have a good idea off hand.
Thanks Pascal.
I really need a working Rhino 64-bit ASAP so I want to try uninstalling and reinstalling.
Can I uninstall it and use the same Activation Code without any problems?
Thanks again,
Julio
Hi Julio - you can reinstall using the same license key you always use.
Hi @pascal ,
I tried uninstalling and reinstalling but Rhino keeps freezing when I click on the Material Panel.
I’m also trying to run Rhino in Safe Mode but I’m experiencing the same problem.
The strange thing is that I can open the same files with the 32-bit version without any problems.
Does Rhino have some texture cache somewhere that I can delete?
How can I fix this?
Thanks,
Julio
I fixed it :grinning:
What I did:
  • Clean all things up with CCleaner;
  • Delete files in the AutoSave folder located here -> C:\Users\ YourUsername \AppData\Roaming\McNeel\Rhinoceros\5.0\AutoSave
I really don’t know what happened but these steps did the trick.
Hi Julio - that is all very strange… I do not have even a slight idea what might have gone wrong nor what fixed it…but I’m glad you got thing working, thanks for letting us know.
