It doesn’t require any work.
Switch any osnap and grid off. You will never draw perfect parallel or perpendicular lines freehand.
Try to achieve, in a 1000 attempts, one perfect result. I bet it’s not possible unless the tolerance is set to very low.
This would be pretty difficult to enforce if the drawing contains many lines which are not at 90° ortho. Every time you wanted to draw something it would need to check parallelism with all previously existing lines.
Then there is also a question of tolerance. What difference in angle constitutes ‘non-parallel’? 10°? 1°? 0.1°?
It would probably be something better to apply after-the-fact then as-you-draw, so that it’s not constantly moving things around…just lay them out parallel then ‘blow them up’…
But really, there are no actual “standards” for patent drawings anymore, it’s just whatever.
Another way of solving it (when you have a drawing already) would be loading it to GH, shatter to segments, extract control points and apply minimal random X-Y distortion and then re-compose the curves.
When I helped a friend with a provisional patent, all the drawings were done with, at that time Penguin, which is built into Rhino now. All the callouts/lead-lines were done in Inkscape. [A patent attorney who also held an engineering degree reviewed it. I heard back that very little needed to be done to it. I could never be a lawyer. I have read legal documents that have sentences, if not paragraphs, without any meaningful information in them at all.]
The thing is, even if you can take sloppy liberties to get your patent past the reviewers, it may still be successfully attacked in court during a dispute.
Anyway, such a tool could be made that:
As the line intersects the magenta line, it is found to be perpendicular.
The line is cut in three pieces by a circle.
The cut section is rotated.
A second circle trims line to make room for radii
Quadradic or interpolated curces are drawn replacing the line.
