Hi
I’m new to VisualARQ and I’d like to turn the plan in the screenshot into a model. Is ther a quick way to create those walls? Extruding and turning into walls gives me a weird result.
Thanks in advance!
Hi @Marek_Wolf,
I see most of these walls are irrgular, so you should use the “Wall from solid” command to create your walls (which I think is the one you have already used).
Which weird results is it giving to you?
Take into account that if you extrude the all the once in a single solid, the “Wall from solid” command will be creating one single wall so maybe you should divide the surfaces before extruding them in order to create walls separately.
Thank you, I will do it like that ![]()
