Is it possible to create a wall style like this:
Hi @simon12, VisualARQ Walls don’t have structural components like that. This is a feature planned for future versions.
However, you can create this kind of walls by combining walls, columns, and beams. If you use GH you can automate its creation. See gh file attached:
(The board could be done also by subtracting stripes on the wall, or using extrusions or even beams instead of a wall.) If you use beams you will get the joints at corners easily.
Thank you very much.
