Trying to open Rhino v8 file in Rhino v7
I will like to ask that how can I open a Rhino v8 file in Rhino v7 which now v8 are not available to used.
You’ll need to open the file in Rhino 8 and save to Rhino 7.
Evaluation versions can be found and used here for 90 days Rhino - Downloads
Does this fix your issue, or are you unable to install Rhino in your current environment?
i believe somebody made a converter, i never tested it, i have no idea if that will work for you.
Thank you so much!! I will have a try on both ways
