Trying to export a Layout into Illustrator (With Layers)
I’m trying to export a layout I’ve already organized in Rhino into Illustrator to work on the linework. However, when I open the PDF in Illustrator, the vectors are recognized, but the layers are lost.
Is there a way to keep both the vectors and the layers intact? Is separating by colors my only option?
Thanks,
Eduard
@Eduard_Carbonell_Igl, Welcome! Can you post your Illustrator file and also the resulting Rhino file after import? If the files are too big, you can use https://www.rhino3d.com/upload and put the address of this thread in the upload description.
Of course:
Layout Print Test.rar (12.9 MB)
This is the rhino model itself
So this is the model and i did some make 2d in top view from the 3d model wich is what i’d like to print (Btw know any other pro tip to make 2d 3d models, i usually get some weird lines and i followed most of this post How to Get Make2D to Perform Better [McNeel Wiki]).
Then i make my a3 layout with the drawing to scale and everthng how i’d like it.
Now i print this layot,i belive this is probably where i do something wrong not sure what though.
The way i temporally solved this was just to make a rectangle the size of an a3 scale it 500 for 1:500 scale etc. but this doesnt allow me to have several scales and i wasnt super keen on scaling the drawings themselves, and the export as ai format.
Print test.pdf (547.4 KB)
This is this layout printed
Sample document.ai (740.9 KB)
This is the ai document and how it looks like on ai so basically lines are grouped in drawings but not in layes if i hide we can see that here:
o
This is how the document looks like inside the ai file and the groups so just ungrouped vectors, i could make one layer a color and then group by color but that might be quite time consuming since i’ll have to redo all the make 2d’s
Hope this is usefull to understand the issue :smiley:
Thx for helping,
Eduard
Hi Eduard -
When I open your PDF in Adobe Acrobat Reader, the layers are there and can be used to show and hide curves.
Adobe’s Illustrator product apparently does not. You’d have to contact them about this to find out why that is the case.
Hey, so i contacted adobe help and basically they said that pdf layers a completely different thing to illustrator layers wich makes sense : Solved: Betreff: Illustrator not recognizing Layers in a V... - Adobe Community - 15013051
I’t would be nice if there was an option to export to illustrator a layout :slight_smile:
This is indeed a difficulty that many users have. I see several possibilities:
Layout to DXF/DWG
This problem will be solved as soon as the page layout can be exported in dxf with a layer hierarchy. The layout will then be imported into Illustrator in dxf and the layers will be recognised.
Layout to AI
The best thing would of course be to be able to export the layout directly to .ai. Rhino only offers this export format for the ModelViewport at the moment.
Rhino Export format also available for LayoutViewport
In fact, it would be best if the Rhino export formats were also available for LayoutViewport and not just ModelViewport. That way, both wishes would be fulfilled at once.
Affinity Designer
It depends on whether you need adobe specific tools. But one solution might be to abandon Illustrator. Affinity Designer recognises pdf layers. It doesn’t have all the tools of Illustrator, but it’s a good program and more affordable than Adobe.
Workaround in the meantime
Export your page layout in PDF format.
Import this PDF with layers etc… into a new Rhino file.
Export it as a DXF/DWG or AI with layers.
Import the DXF/DWG or AI into Illustrator
