When I export from Rhino to Illustrator and I have nested layers in Rhino, each layer comes into Illustrator with “::” between the parent and the child layer names. For example:
Make2d::Visible::Walls
Make2D::Visible::Floors
Is there anyway to have the layers show up as nested layers in Illustrator as well?
Also, could you add an export option to Illustrator that explodes hatches (except for solid hatch)? Right now when I’m exporting hatches I have to manually explode them, export, then undo the explode so that I keep them as hatches in Rhino. It would be much easier if Rhino could explode them as part of the export. Or if I were to really dream, it would be amazing if Rhino could create an Illustrator pattern swatch that matched the Rhino hatch so that it would be a fill pattern in Illustrator too. Maybe for V6?
Hi -
I’m still hoping to see layer nesting for AI export in a future update. I’m using Rhino 6 SR19 and AI export still operates like Jacob described it…turning each Rhino sublayer into individual layers in Illustrator. For example:
Came here looking for the solution, saw this post, decided to add another voice for this feature, since it is already possible to have sublayers in AI. Also AutoCAD has something like that implemented.
(Rh 6.25, no changes in this regard)
If there is some solution to this, it would be very helpful; as when you have 500 layers/sublayers nested nicely in rhino; become 500 individual layers in illustrator, it takes a lot of time to ‘re-nest’ them.
Anyways, still amazingly appreciative of the community feedback and product improvement here. It’s interesting to note that Illustrator and Indesign are very inefficient at dealing with the kinds of outputs possible with Rhino. They seem to become bogged down as they don’t seem to be designed to handle so many curves.
Hi Jeremy - I noticed that Rhino also opens these nested PDF files un-nested and put that on our list as RH-61109. I wouldn’t go as far as saying that will have an impact on how these are written from Rhino but who knows…
