Trying to create a name ring, probably missing something simple
Hi folks,
I’m trying to create a simple name ring by following the process shown in this video. I have no problem creating the curves, but I can’t seem to get the actual command (Sweep2?) to work. I’m at the point where I’ve modeled the first image, but I can’t get it to become a solid.
I know this has been a while, but I was browsing and came across the post. You will need to split your outer ring rail curve at the bottom, to create two halves. At least, from the video, that’s what it appeared to be from the sweep.
It looks like that might be what you have already, I can’t tell. If so, can you post what happens when you do run the sweep?
