Try this to improve jagged wire rendering in Rhino 8
There is a hidden command in Rhino called TestWireThicknessScale which basically lets you change the wire thickness of curves, surfaces, isocurves, SubD and meshes. I often read here that Rhino 8 users have troubles with the anti-aliasing of the wires. I found that setting a value of 1,5 makes the wires relatively smooth, albeit they become a bit thicker than before.
There is also an option to make this command automatic upon starting Rhino. To do so, you have to include it into the list of commands that will start with Rhino. For example, if I want to have 50% thicker wires in Rhino 8, I enter the following command in this window:
testWireThicknessScale Enabled=On Scale=1.5 Enter
Thanks for sharing your knewledge !
Had high hopes for a moment, but makes a line thicker which despoils the finesse I like to feel with CAD. and need for accurate working and picture tracing etc.
More a primary school cheap CAD prog.
Steve
This works if the default line thickness is already 1 pixel. However, Rhino 9 BETA has 2 pixels wide wireframe by default, so you have to reduce it back to 1 from the settings of each display mode. Then, you can apply the testWireThicknessScale Enabled=On Scale=1.5 Enter command and see it improve the anti-aliasing a little bit.
I can’t find a global setting to change the wireframe thickness of all display modes simultaneously.
Perhaps we need a new feature request for this?
