i’m setting rhino 6 and there are a few things i can’t figure out. the wire frame in 6 is way thicker than it is in rhino 5 and i can’t find a way to adjust it ? also when i click on wire frame the control points come on and i can’t find a way to turn this off ? any help would be much appreciated.
Hello - use testWireThicknessScale to set the wireframe - if you find a number you like, you can set it in Options > Advanced > WireThicknessScale.
You can control the points-on behavior in Options > Mouse page > “selection” area.
