Hi!.
Well. I’ve been trying to make all documentation inside rhino and using visualArq.. it is tricky.. I still hope it can be done. For this I rely a lot on the “plan views”.. and “section views”
A big problem I found today is that the Dashed lines inside the plan view are printed incorrectly in using wireframe viewstyle.(this problem is solve is I explode the plan view.. so the problem is the planview itself)
BUT.. if I switch to HIDDEN viewstyle, the Dashed lines print ok.. but all other regular blocks inside rhino are completely destroyed in the print.
So my guess is about how Visualarq interprets the units (failing to render a dashed line as many small segments.. or converting a circle into a square on the other case). but it is unerving that the “print preview” is displaying something correclty, but print that is not possible.
I’ll appreciate your help in solving this issue. allowing to print either in wireframe or in hidden viewstyle.. Thank you!.
(system information at the end of this message)
TEST_DRAWINGS_WIREFRAME.pdf (45.1 KB)
TEST_DRAWINGS_HIDDEN.pdf (28.5 KB)
TEST_DRAWING.3dm (5.6 MB)
Rhino 8 SR28 2026-1-21 (Rhino 8, 8.28.26021.13001, Git hash:master @ 13ca4c596ccf597975b83e41bd87ab486f6c3f4a)
License type: Educational, build 2026-01-21
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.14
Primary display: AMD Radeon™ 780M (AMD) Memory: 1GB, Driver date: 6-27-2023 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-7-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.97
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-7-2025
Driver Version: 32.0.15.8097
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\mutar\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\25.3.0.0\bella_rhino.rhp “Bella” 25.3.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.28.26021.13001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
