Hi
Im having trouble trimming off the surface outside my curve, on this surface.
I have made the surface as a patch, from the curve but the “automatic trim” didnt work.
Any ideas?
Hi
Any ideas?
And also maybe a better way of making the surface.
The patch function gives me a more flat surface than I would like.
Sweep, loft etc.???
Can you post a file please?
It could be a problem with the curve or with a command option.
There’s no curve in that file and now it’s a polysurface so the game has changed.
If it’s going to be a polysurface, extrude your curve into a ribbon surface that intersects the polysurface, then check the normals and use a Boolean.
I’m making a lot of assumptions there.
