Trim Crash
I’ve had something weird suddenly happen to a file. In this sample file if I try to trim off the bottom of the red extrusion using the plane, the whole exstrusion disappears and Rhino crashes with a memory allocation error?? Split works.
trim error.3dm (144.4 KB)
Same behavior here.
If I ConvertExtrusion the red object the same behavior.
However if I Explode the red object then it trims properly.
Explode the red object and then Join the three parts the same behavior.
So it appears the joining is causing the problem.
Rhino 7 SR8 2021-6-9 (Rhino 7, 7.8.21160.05001, Git hash:master @ 9070c33ca93e552d4fa2ae1038d65e6ff1ded0e8)
License type: Commercial, build 2021-06-09
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 5-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-6-2021
Driver Version: 27.21.14.6259
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.21.0
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.2\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.2.0
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
D:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21160.5001
D:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
D:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.8.21160.5001
D:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
D:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.8.21160.5001
D:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
D:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.8.21160.5001
D:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21160.5001
D:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.21.831\SectionTools.rhp “SectionTools”
Hi all -
This is a know issue in the service release candidate. It has been fixed and the next release candidate should be fine.
For now, revert to Service Release 7.
I thought instead of trying to roll back I’d just use the WIP…it worked for a while, then DID appear there?? What the–?
Still seeing this in SR8.
As Wim said, we’re aware of it and I think it was fixed for V7 SR8 SRC2, what what supposed to be released this week.
The best option for now is to uninstall V7, reinstall V7 SR7.
That said, we very much appreciate the users that use the Service Release Candidates. This is how these problems are caught so they can be fixed before the actual Service Release is available.
V7 Service Release 8 Candidate 2 was released several hours ago.
The trim bug appears to be fixed based on some quick testing.
Exactly which version of SR 8 are you using?
Rhino 7 SR8 Release Candidate 2 for Windows and Mac (7.8.21168) which was released today
or
Rhino 7 SR8 Release Candidate 1 for Windows and Mac (7.8.21160) which was released last week ago and has the bug
I confirm that Today’s service release candidate (Rhino 7, 7.8.21168.01001) candidate solved the issue.
Thank you everyone
