Triangulated surface
Hi There,
What am I missing here?
there should be lines connected to each point creating a triangular pattern like the image below.
any help is much appreciated!
Triangular surface patterning.gh (16.6 KB)
You can modify the minimum(N0) and maximum(N1).And use Cull Index to remove the duplicate points…And the other offset should be {0;0},{1;0},{1;1}.
You do not need the Merge.This is more elegant.
Amazing, appreciate it thankyou.
