Is there a way to apply this triangular grid facade to the triangle panel on the curved surface ?
Screenshot of facade GH file
parametric facade.gh (17.3 KB)
parametric facade.3dm (233.4 KB)
Does anyone know a solution ?
Thank You
Thank You
See attached
Map_to_surface_EntryLevel_V1.gh (18.5 KB) Map_to_surface_EntryLevel_V1.3dm (620.8 KB)
BTW: Morphs work on Surfaces (not BrepFaces) meaning that if you have triangles in mind you should represend them as untrimmed Surfaces (with a singularity).
