Transparency problem render vs raytraced
I think this might be a bug. In the attached file the texture looks proper in rendered mode but in raytraced or when I do a rendering the transparency drops out and the object renders as solid.
How it looks in rendered mode.
How it looks in Raytraced mode.
I used create pbr from files and created the textures they seem to be ok. I attached the file with textures.
RM
RenderViewTransProb.3dm (13.7 MB)
I moved the opacity map to the alpha
Hi @Japhy
Thanks for taking a look.
When importing, using the “create pbr from files” I merely selected those files and I expected Rhino to put the transparency map into the correct slot. I guess if you accept the defaults Rhino defaults to amount instead of alpha channel. I think alpha channel should be the first choice for default, I don’t use those other options at all I always only use the alpha channel. Hope that can get tunned up.
Thanks for your help and clarifications.
RM
