Transom Window in Plan?
Whats up folks,
How do I allow the transom window to show up in my plan view? Is there some sort of option to override cut depth so that the window will be represented?
Hi @Denzel_Hill, you can change the window plan visibility from the Window properties panel > Display > Plan Cut Elevation > Middle (you can also set a specific cut height)
A short video about this: https://youtu.be/fJSbR_gutzs?si=vmmM7OPmEGKhF-t-
