Hi all,
I am trying to replicate my workflow from a proper BIM tool to VA3. Here below I have Window with Sill level 3ft from plinth level and when I toggle plan mode I could see the window cut on plan as seen below (cut plane is at 4ft level)
But I also have a Ventilator at 7 ft sill height at same plinth level (above cutplane) and I want to show that on plan as hidden line. How can we show overhead VA objects / elements such window (above cutplane) in VA on plans?
Is the window and the ventilator inside the level that you are displaying in plan view? if these objects are located on a different level, they won’t show up in the overhead representation.
Please share a file so I can check if there is any error.
One window is at 3ft sill level and other one at 7 ft sill level. The cut plane is at 4ft. the window at 7ft sill level needs to be seen as dotted line on wall.
@asisintel you are right, there seems to be a bug here. The window upper window should be displayed in the plan view. I’ll report that and get back to you when we fix it.
