I’m struggling with the transformation from two similar Triangles in parallel Planes to a closed Brep
I’m trying to represent the process of making a 3D triangulated Wall out of Plywood in Grasshopper to get a template to use on other Plywood Walls Designs. In the Design I will get one Mesh or Polysurface. Till now I managed to define the Base Surface and its projected Surface. Now I cant figure out how to make a closed Brep out of these two Similar Triangles in parallel Planes. The goal is to get the exact Plywood Panels Measurements. Especially the edges angel between two panels. For they are of the dividing angel of the Normals of the two panels.
Adding Pictures of the Grasshopper Algorithm, the Mesh Input Wall, the Point at which I am and a Detail with scribbles, as well as the Process Grashopper File and an internalised Grasshopper File of the Point I got stuck.
Triangulated3DSurfaceForQuestioningTheProcess.gh (28.2 KB)
Triangulated3DSurfaceForQuestioningJustInternalizedSurfaces.gh (13.9 KB)
