Hello everyone, I have a problem when trying to create a closed brep.
I’ll try to be brief: I want to create shapes that resemble stone bricks. I started with a parallelepiped and generated many points on the side faces, which I then moved randomly to create 4 lofts. Everything was fine until I joined them with a brep join, which generated a closed brep.
The problem arises when I try to generate the top and bottom surfaces. I selected the jagged edges of the 4 sides and created a surface with edge surface. However, when I join them with brep join, it leaves me with 2 open breps and 1 closed one. In the screenshot, the inputs d1 and d2 in merge are the 2 top and bottom faces, while the others are the lofts of the 4 side faces that generate the closed breps.
I’m new to modeling with Grasshopper and have tried to find a solution before posting this. Can anyone help me and tell me where I’m going wrong?
