I thought that a way to do it in grasshopper is with multiple attractor points. My problem is that when i set multiple points as attractor points it creates a different point grid for each attractor.
What if I would like the transformation length of each point to have the same length with the vertical distance of each point to my base surface?
I used closest point in order to count the distance of each point from surface but I think that I dont know the right way to connect them on remap target .
I’d like to have different heights for each of points, using your definition above. How would I do that? Currently all of the points are pushed to the same height.
(More than one point controling their own heights, on the same surface)
Thanks,
hi do you know how i can create a surface which is not joined by 4 sides such as this? Btw i am using the same script which you have used so thanks for that
Assuming the script is the same as the original - something interesting happens here, the first ZVector is redundant, instead of putting your negative at 1, place it at 2 - OR, remove the first ZVector and just feed the values straight from Multiplication into MassAddition
