I want to transfer the Revit model into rhino and organize it in layers and sublayers.
Each main layer should have the name of a rhino phase, e.g. existing, excavation etc.
Each face contains multiple Revit categories. E.g. phase 5 in Revit contains some beams a stair and some floors.
I want these to be the sublayers of the main layer.
E.g. in rhino for Revit phase 5 i will have:
groundFloor beams stair slab (main layer) beams (sublayer with all beams created in phase 5) stair (sublayer with all stairs created in phase 5) floors (sublayer with all floors created in phase 5)
I am able to query and filter the Revit model by category, but I want to start by filtering by phase. Is that possible? I understand that phase is a parameter for all Revit categories.
in Revit, left to phase name is the phase order. This is the order i want in rhino too. Can we read this Information?
A workaround id not is to place a number before phase name in revit. e.g. 0-phase 1, 1-phase whatever …e.t.c.
If i place manual the number in the start of name face, then i should always renumber if i add a phase between which is not efficient. But if we can read the number left to the phase in Revit, then the procedure will be automatic. Can we read this is the question. Or can we make a custom component using Revit API to do that? e.g in my screenshot New Construction is number 28. If i add a phase before then the number will be 29.
Thanks
