Hello!
I was wondering how can I loft or create a shape from 2 or more curves and take a triangular result instead of double curvature surfaces. Is it possible with loft command or I have to use another method to achieve this?
Thank you!
Triangulate Loft.gh (13.4 KB)
IMHO, there’s no loft that can produce such. You should subdivide it after loft.
Thank you HS_Kim. Cause I saw that and I was curious where is Triangulate option.
Find the source of the image and check it directly with the creator.
Looks like they just converted to mesh.
