Hi, I am new to grasshopper. Could you please tell me how to create a Loft surface from several curves in grasshopper?loft surface using parabola.gh (6.6 KB)
Plug the curves as a flat list into loft.
could you please show with an example code?
Plug them both into curve. Then curve into loft.
i tried. I can’t wire two curves at one point. when i connect one, other gets disconnected. Please check the file attached in the quesiton.
You didn’t attach any file. Shift+drag to connect multiple.
shift +drag
Thanks a lot
Just go to Help>Tutorials. Go through all those before using Grasshopper
