I have to load my toolbar every time rhino opens - is there a way to make it stick.
thx,
Keith
thx,
Keith
Hi Keith
In the âToolsâ toolbar there is a button called
âSave open toolbar collectionsâ
Does that work ?
Thanks Emilio, I can not see a âSave open toolbar collectionsâ. Options > toolbar layout>
Is there a command i can write straight into Rhinoâs command line ?
Regards,
Keith
Yes
The command in that button I have here is:
! _-Toolbar _Collection _Saveall _Enter _Enter
HTH
Emilio, the toolbar is still not saving in place. It is however saving a rui.bak file
Would you like to connect to my computer ?
Keith
Hi Keith - try:
Close all Rhinos. Make sure none is running ârogueâ by looking in Task Manager > Processes - stop any Rhino processes that you see.
Right click on the Rhino icon and choose âRun as Administratorâ. Sort out the toolbars, close Rhino, start again nornally - does that behave any better?
Thanks Pascal, it still refuses to stick !
Is there anything in the registry i can clear ?
Keith
Hi Keith - is this your own custom toolbar? Try putting it in the default location (if it is not already) with SaveAs in the Toolbar page of Options >FIle menu. The default location is
C:\Users\YOUR_USERNAME\AppData\Roaming\McNeel\Rhinoceros\5.0\UI
Does that make any difference? It should work if the location is a writable one, but just try the default. Has it always been this way, by the way?
Pascal and Emileo,
I got it to stick by removing the entry in HKEY_CURRENT_USER\SOFTWARE\McNeel\Rhinoceros\5.0x64\Scheme: Default\Window Positions\Docking Toolbars\ Closed Rui Files
Not sure why adjusting this registry key helped - but it did
Keith
Makes sense. No, really! =)
Ok, thanks for letting us know.
Thanks for the info, Keith !
