I would like to know how to add label with leader in the various detail views for a global point programmatically?
I am unable to get the equivalent location from the world system to the detail viewport / page viewport…
I have attached a test job file and the expected output.
When a button is clicked, a page view with detail views including the labels in the page view plane is needed.
A sample code to achieve this would be appreciated.
Also two other things:
is there a way to label in a specific format (text within a circle attached to a leader).
This is typically a text dot which is not filled.
Is there a method to check if the labels overlap? TestLabel.3dm (51.3 KB)
