Coordinate label RHINO 6
Hello.
Is there a way to make a label which is bonded to a point. which shows coordinate x, y, z.
I can easily make it in grasshopper but after baking it the binding of course is gone.
Somthing like a dynamic block in A-CAD.
thanks.
Hi -
In Rhino 7, you can use the PointCoordinate text field.
thanks.
Sorry Rhino 6.
i got this, but it does it with text dots :expressionless: i’ll dig a little more but someone probably has a better script for your purposes
Option Explicit
Call CalloutDotXYZ()
Sub CalloutDotXYZ()
	Dim strObject, arrPointEnd, arrPointStart, strPointStart, intStyle, arrPline
	arrPline = Rhino.GetPolyline
	If IsArray(arrPline) Then
		strObject = Rhino.AddPolyline(arrPline)
	Else Exit Sub
	End If
	'strCallout = Rhino.StringBox("Enter text for callout:",, "Callout Text.")
	If Rhino.IsCurve(strObject) Then
		arrPointEnd = Rhino.CurveEndPoint(strObject)
		arrPointStart = Rhino.CurveStartPoint(strObject)
		strPointStart = Rhino.Pt2Str(arrPointStart, 3)
		Rhino.AddTextDot strPointStart, arrPointEnd
		'Rhino.AddTextDot strCallout, arrPoint
	End If
	If Rhino.CurveArrows(strObject) <> 1 Then
		Rhino.CurveArrows strObject, 1
	End If
End Sub
this one is closer. i’m not that good at scripting so i’m not sure how to change it to have the equals sign.
Option Explicit
'Script written by <insert name>
'Script copyrighted by <insert company name>
'Script version Tuesday, March 2, 2021 12:29:50 PM
Call xyzLeader
Sub xyzLeader
	Dim arrPoint ,tokens ,token ,preView ,curView ,arrPlane ,preArrPlane, arrPoints
	preView = Rhino.CurrentView
	preArrPlane = Rhino.ViewCPlane(preView)
	curView = Rhino.CurrentView
	arrPoints = Rhino.GetPoints(True, False, "Select leader point")
	If IsArray(arrPoints) Then
		arrPlane = Rhino.ViewCPlane(curView)
		arrPlane(0) = arrPoints(0)
		Rhino.ViewCplane curView, arrPlane
		tokens = Rhino.Strtok(Rhino.Pt2Str(arrPoints(0), Rhino.DimStyleLinearPrecision(Rhino.CurrentDimStyle)), ",")
		Rhino.AddLeader arrPoints, curView, "X " & tokens(0) & VbCrLf & "Y " & tokens(1) & VbCrLf & "Z " & tokens(2)
	End If
	Rhino.ViewCplane curView, preArrPlane
End Sub
i’ll even throw in my custom icon :wink:
XYZ LEADER
@kleerkoat - in case this helps -
Option Explicit
Call xyzLeader
Sub xyzLeader
	Dim id: id = Rhino.GetObject("Select the point object", 1, True, False)
	If isNull(id) Then Exit Sub
	Dim pc: pc = "W" & Rhino.Pt2Str(Rhino.PointCoordinates(id))
	Dim strText: strText = chr(34) & "%<PointCoordinate(" & chr(34) & id & chr(34) & "," & chr(34) & "XYZ" & chr(34) & ")>%" & chr(34)
	Rhino.Print strText
	Dim cmdStr: cmdStr = "#_-Leader " & pc & " MultiPause " & strText & " _Enter"
	rhino.Print cmdStr
	Rhino.Command(cmdStr)
End Sub
nice! thank you!
Thx, that’s great.
