Tiny small bug in Block Attribute User Text / or improvment
If the user enters a “Value” in the property field to the right and then goes on to do something else, the value changes back to what was before. Either “tab” or “enter” is required for the value to change.
I think the value should change even when there’s no “tab” or “enter” pressed. I often need to retype the new value / text string, because it is lost.
Thanks
/Erik
Hi @erik6 can you run the SystemInfo command and copy / paste the results here so I know which specific build and version we’re talking about.
I was unable to repeat this issue in 8.36 so if you’re running that version I’ll need more specific steps to repeat the issue in order to be more helpful.
Rhino 9 SR0 2026-9-29 (Rhino 9 BETA, 9.0.26272.12303, Git hash:master @ b5f5102690615c89acabfc68e24eae200f3d735b)
License type: Commercial, build 2026-09-29
License details: Cloud Zoo
Expires on: 2026-11-13
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 95GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 7-22-2026 (M-D-Y). DirectX(11)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) Graphics (Intel) Memory: 2GB, Driver date: 10-11-2024 (M-D-Y).
- There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\Erik\AppData\Roaming\McNeel\Rhinoceros\9.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 9 WIP\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
I’m quite sure it has nothing to do with the D5 plugin.
Thanks!
Unfortunately I cannot repeat this in 9.0 either.
Starting with you have the value cell in edit mode..
Specifically, how are you clicking away or changing focus that causes it not to stick?
value not sticking
Here is a small film showing that the value is not sticking.
Enter the value and the click in the Rhino viewport. Then go back to the block attributes. The value is gone.
Thanks for the video. When I follow those steps it works as expected.
Does the problem go away if you left click below the cell before clicking into a viewport?
