I found that the value that I changed manually in the User Text panel was unchanged after all.
I have many of objects with attributes of keys/values, and then select objects, start typing in the search box to narrow down the list, change the value and press the enter key.
I tested the simple samples, and even in the safe mode but the problem is still there. It’s weird that the keys “updated” and “width” have this problem but “height” does not.
Does this happen to you? Can I fix it?
Rhino 7 SR16 2022-3-8
UserTextSearchTest.3dm (14.2 KB)
