With the significant improvements in Rhino about renderings, it could be essential to add the camera tilt/shift command (for use in architecture, it’s fundamental).
There is one ‘automatic’ version and that is the 2-point perspective projection. Not tilt though, essentially just shift in a way.
edit: that said, I logged this feature request: RH-78536 Control for camera tilt and shift
Thanks for your reply. I use the Two Point Perspective as the principal projection for architectural renderings. Still, it could be essential to"SHIFT" the view without moving the point of view and the target, shifting the camera.
Thanks for adding the request.
