Why is not possible to tilt the camera vertically in Two Point Perspective mode? Am I missing something?
good question, the shortcut for tilting with alt shift also has no effect. i dont see anything that could limit this function since it would be just rotating the 2 vanishing points, is that something you need often or what is your purpose for this if i may ask?
As I work in the archviz industry, yes its kind of vital command that is missing. I installed a small python script called DIG_TwoPointPerspectiveNavigation that allows to tilt vertically the camera but still, it seems a useless limit…
Hi -
We have the feature request on the list as RH-32178 Two Point Perspective Views - changing and setting suggestions.
thanks Wim, I hope there will be some development regarding this topic in the near future.
Cheers
Hi Wim,
I want to give a thumbs up on this feature too.
Not being able to camera target in 2point perspective is pain for architecture modeling.
I know there are workarounds but it shouldn’t be too hard to implement this feature more appropriately right? since Rhino already kind if does that.
HI Ian -
I’ve added your vote and comment to the ticket.
Thanks,
is any update available regarding this topic?
Hi a2rc -
You can always check the latest activity in RH-32178 Two Point Perspective Views - changing and setting suggestions.
This is currently on the “Future” list.
