The transparent idea
I can’t seem to find a comfortable layout to work in Grasshopper.
Although I have a 4K - 32" screen, with Rhino and Grasshopper side-by-side, I always feel in a cramped condition.
GH definitions are typically elongated horizontally, which does not help.
I wonder if the solution would be to have a “Canvas transparency” slider in the GH UI, so that, while still having the pointer focus in GH, the Rhino UI could be seen underneath.
Have you tried this one?
I support that idea. I just feel really comfortable when I can work on 2 screens.
These idea exists really long. I saw a few VB scripts in the old forum to manipulate the canvas color, grid, transparency. Didn‘t testet them out in v6.
But I think this will only improve on „small“ Projects. Editing one form or something like that. Having a large script infront of a large project won’t work for me. Than I also need to let one side of the script free, so I can see what‘s going on, on the other side.
So I think this would be a nice gadget, but not necessary/high priority.
Oh, there was someone faster :smiley: yes these are the links I meant
How would you feel about having GH be in a Rhino viewport? It’s something I’d like to try for GH2 as a way to get around child-window-hell.
Or: https://github.com/mcneel/GhCanvasViewport
Hopefully soon to be available via PackageManager.
Could be awesome. If there’s a nice solution with the additional gh canvas.
Some horizontal splitsscreen would be something in my imagination. At the top 3D viewport and on the bottom side grasshopper.
For viewport in Rhino, I think it would be nicer if it’s nearly a square, but gh is more horizontal
You can resize viewports in Rhino all your like. Float them, dock them, maximise them. I have no idea how this would play with Layout, but if we can host Eto controls in viewports, then it should be possible.
If gh viewport will be editable like rhino, it won’t be a problem :slight_smile:
Hi David,
I’m not sure this is a good idea : when I work in GH, Rhino is mostly a commodity, so I need the GH UI to be as large as possible.
I’ll stick with my suggestion of controlling the alpha of the canvas ; here’s what it could look like with a tunable linear blend and a drop-down list for which half of the screen to make transparent :
I just realized that the 3D mouse still works in the Rhino Viewport when GH is in focus.
It’s the reason we can’t use it with Grasshopper, but ironically, it’s a great feature when combined with the “Wormhole” thingy.
It’s the reason for a Width parameter.
Check this:
CanvasRhinoView.gh (2.7 KB)
I’ve created a YouTrack entry for this pointing to this discussion, so whatever opinions and ideas you still might have this is a good place to put them.
I’m going to focus on this next week. Hopefully we’ll have something people can play with very soon
It would be handy to occasionally (or often) have the model and the definition on the same viewport (like when using laptop), I like using Daniel’s wormhole definition in a presentation. How about an effect as in Dynamo’s interface where the nodes and wires superimpose onto the model viewport, (maybe use of transparency), would be useful to somewhat control the effect or turned off as needed.
I personally hate the way this looks, but it is something we can look into. There are some pretty stiff limitations on what can be done with window transparency, especially on cross-platform UI frameworks. It is possible on Windows to assign a single colour to be transparent per window/control. I think this approach is the one used by the existing plug-ins/scripts for GH1. The problem with this is that it results in really ugly anti-aliasing artefacts when shapes are drawn on top of it. I imagine there might also be an issue of trying to do the same on Mac.
But instead of true transparency so you can see a ‘real’ viewport underneath. it may be possible to render a custom viewport to a bitmap which is used as background for the canvas. Such an approach would even allow for partial or variable transparency as @osuire suggested in the 12th post. There are other benefits to rendering our own viewport background as well, as it will be much easier to control exactly what geometry will be visible and how it’s drawn. Downsides of not using real viewports is that a lot of functionality will have to be re-implemented, and it probably isn’t all going to be.
For me the best option is to have interactive viewports as components that only preview the input geometry. And with a double click, they can be raised to/removed from the control context of the canvas.
I really like that idea David, it’d work well using GH/Rhino on a laptop, less clutter and confusion than see-through viewport.
