does it already work? Would you like to share?
This is sort of close to what I was planning anyway for the Panel in GH2. The problem with the current panel is that it converts everything into plain text, whereas most people use it to inspect data. So ideally a panel wouldn’t change the data at all, but instead display it using a variety of mechanisms (plain text, rich text, images, 3d views). See: Could Grasshopper2 improve cognitive management through a dedicated component? - #17 by DavidRutten
It’s photoshopped.
I think it’s great to do it with the panel, David.
In addition to using it to display the data, I use the panel as a source parameter very often, to differentiate between a dynamic source with the slider (which is intended to be changed frequently) and a static source with the panel (which in principle does not need to be changed, such as a tolerance). Regarding converting the data to text, yes, I don’t find it very useful.
I strongly second this idea, brilliant.
I use a panel component and two tree viewer components grouped as a floating inspector.
It would be great to have an object viewer window that could be attached to an output
waii, el que mas me gustó fue este.
