The italic icon remains active in the Create Text window
What I’m writing below happens both in the Create Text window and in the Text Object.
I run any of the commands mentioned above, I write a text and press Enter and place the text in the window that is active at that moment. I run the Create Text command again, I write my text and this time I want it in italics and I activate the corresponding box and insert it in the active window. But if I open the Create Text window again and now I want a new text without it being in italics, even if I deactivate the italics box when I insert the text in the active window it appears in italics and I can’t even write normal text again even if I change the text type, give it another height etc. it always appears in italics.
The only way to write normal text is to close Rhino and reopen it.
I hope I’ve explained myself well.
Text dubbed into English by Mr. Google
SystemInfo Attachment:
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, revisión 2024-10-08
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\CesarTG\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “HerramientasParaSólidos”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “NavegadorWeb”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Bonus Tools de Rhino”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Herramientas Rhino Labs”
C:\Program Files\Rhino 8\Plug-ins\export_STL.rhp “Exportación STL”
C:\Program Files\Rhino 8\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “Herramientas de animación”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “ProcesadorInactivo”
C:\Program Files\Rhino 8\Plug-ins\Squish.rhp “AplanarAvanzado”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Renderizado de Rhino” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Renderizado de Rhino de versión anterior”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\ShrinkWrap.rhp “ShrinkWrap” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\QuadRemesh\QuadRemesh.rhp “QuadRemesh” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Import_PDF.rhp “LectorDePDF”
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\import_OBJ.rhp “Import_OBJ” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Export_glTF.rhp “Export glTF” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.12.24282.7001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\import_E57.rhp “Importación E57”
C:\Program Files\Rhino 8\Plug-ins\import_points.rhp “Importación de puntos”
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MPlane.rhp “PlanoM”
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 8\Plug-ins\import_3MF.rhp “import_3MF”
C:\Program Files\Rhino 8\Plug-ins\Export_FBX.rhp “Exportar_FBX”
C:\Program Files\Rhino 8\Plug-ins\MeshFromPoints.rhp “MallaDesdePuntos”
C:\Program Files\Rhino 8\Plug-ins\RhinoScriptEditor.rhp “RhinoScriptEditor” 8.0.23161.1000
C:\Program Files\Rhino 8\Plug-ins\Import_FBX.rhp “Importación_FBX”
C:\Program Files\Rhino 8\Plug-ins\export_SAT.rhp “Exportación ACIS”
C:\Program Files\Rhino 8\Plug-ins\import_DGN.rhp “MicroStation file import: import_DGN”
C:\Program Files\Rhino 8\Plug-ins\import_LWO.rhp “Importación Lightwave”
C:\Program Files\Rhino 8\Plug-ins\Import_glTF.rhp “Import glTF” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\import_VRML.rhp “Importación VRML”
C:\Program Files\Rhino 8\Plug-ins\export_3MF.rhp “export_3MF”
C:\Program Files\Rhino 8\Plug-ins\export_X.rhp “Exportación X”
C:\Program Files\Rhino 8\Plug-ins\export_RAW.rhp “Exportación Raw Triangles”
C:\Program Files\Rhino 8\Plug-ins\import_AMF.rhp “Import_AMF” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\import_SLC.rhp “Importación SLC”
C:\Program Files\Rhino 8\Plug-ins\export_USD.rhp “Export USD”
C:\Program Files\Rhino 8\Plug-ins\import_DST.rhp “Import_DST” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\export_LWO.rhp “Exportación Lightwave”
C:\Program Files\Rhino 8\Plug-ins\export_WMF.rhp “Exportación Windows Metafile”
C:\Program Files\Rhino 8\Plug-ins\export_VRML.rhp “Exportación VRML/X3D”
C:\Program Files\Rhino 8\Plug-ins\export_OBJ.rhp “export_OBJ” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\export_AI.rhp “Exportación de Adobe Illustrator”
C:\Program Files\Rhino 8\Plug-ins\export_XGL.rhp “Exportación XGL”
C:\Program Files\Rhino 8\Plug-ins\import_M.rhp “Import_M”
C:\Program Files\Rhino 8\Plug-ins\CreaseAngle.rhp “ÁnguloDePliegue”
C:\Program Files\Rhino 8\Plug-ins\export_points.rhp “Exportación de puntos”
C:\Program Files\Rhino 8\Plug-ins\import_OFF.rhp “Importación OFF”
C:\Program Files\Rhino 8\Plug-ins\export_SKP.rhp “Exportación de SketchUp”
C:\Program Files\Rhino 8\Plug-ins\export_POV.rhp “Exportación POV-Ray”
C:\Program Files\Rhino 8\Plug-ins\Tutorials.rhp “Tutorials” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\import_PLY.rhp “Importación PLY (formato de archivo de polígonos)”
C:\Program Files\Rhino 8\Plug-ins\import_STEP.rhp “Importación STEP”
C:\Program Files\Rhino 8\Plug-ins\export_RIB.rhp “Exportación RenderMan”
C:\Program Files\Rhino 8\Plug-ins\digitize_MicroScribe.rhp “Digitalizador MicroScribe”
C:\Program Files\Rhino 8\Plug-ins\export_STEP.rhp “Exportación STEP”
C:\Program Files\Rhino 8\Plug-ins\export_IGES.rhp “IGES Export Plug-in” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\export_wamit.rhp “Exportación WAMIT”
C:\Program Files\Rhino 8\Plug-ins\import_IGES.rhp “Plug-in de importación IGES”
C:\Program Files\Rhino 8\Plug-ins\export_VDA.rhp “Exportación VDA”
C:\Program Files\Rhino 8\Plug-ins\import_X.rhp “Importación X”
C:\Program Files\Rhino 8\Plug-ins\import_RAW.rhp “Importación de triángulos RAW”
C:\Program Files\Rhino 8\Plug-ins\export_SLC.rhp “Exportación SLC”
C:\Program Files\Rhino 8\Plug-ins\Walkabout.rhp “Paseo”
C:\Program Files\Rhino 8\Plug-ins\export_UDO.rhp “Exportación Moray”
C:\Program Files\Rhino 8\Plug-ins\import_SCN.rhp “NextEngine Import”
C:\Program Files\Rhino 8\Plug-ins\MeshTools.rhp “HerramientasParaMallas”
C:\Program Files\Rhino 8\Plug-ins\export_GTS.rhp “Exportación GTS”
C:\Program Files\Rhino 8\Plug-ins\digitize_Romer.rhp “Romer Digitizer”
C:\Program Files\Rhino 8\Plug-ins\import_WAMIT.rhp “Importación WAMIT”
C:\Program Files\Rhino 8\Plug-ins\export_XAML.rhp “export_xaml” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\export_SVG.rhp “Export SVG” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\import_STL.rhp “Importación STL”
C:\Program Files\Rhino 8\Plug-ins\import_VDA.rhp “Importación VDA”
C:\Program Files\Rhino 8\Plug-ins\import_SKP.rhp “Importación de SketchUp”
C:\Program Files\Rhino 8\Plug-ins\export_PLY.rhp “PLY - Polygon File Format Export” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\export_CD.rhp “Exportación Cult3D”
C:\Program Files\Rhino 8\Plug-ins\export_GHS.rhp “Exportación de hidrostática general (GHS)”
C:\Program Files\Rhino 8\Plug-ins\export_DAE.rhp “Export_DAE” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Import_SolidWorks.rhp “Importación de SolidWorks”
C:\Program Files\Rhino 8\Plug-ins\export_3DS.rhp “Exportación 3D Studio”
C:\Program Files\Rhino 8\Plug-ins\export_X_T.rhp “Exportación Parasolid”
C:\Program Files\Rhino 8\Plug-ins\digitize_Faro_Titanium.rhp “Digitalizador USB Faro”
C:\Program Files\Rhino 8\Plug-ins\import_GHS.rhp “Importación General Hydrostatics (GHS)”
C:\Program Files\Rhino 8\Plug-ins\export_AMF.rhp “Export_AMF” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\export_CSV.rhp “Exportación de valores separados por comas”
C:\Program Files\Rhino 8\Plug-ins\import_SVG.rhp “Import_SVG” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\import_GTS.rhp “Importación de triángulos GTS”
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Posición guardada”
This is a known problem with the following YouTrack issue: https://mcneel.myjetbrains.com/youtrack/issue/RH-63361/TextObject-Persistent-Italic-and-Bold
Thank you very much Steve Fuchs for your review. This past dawn I read the posts you indicated in the link. And after trying several combinations I have arrived at the simplest solution -which is often right before our eyes- without having to restart Rhino.
As a rule or habit, we usually click on the icon to deactivate the generation of text in Italics and then write the new text but in the case we mentioned this method does not work since the text continues to be generated in Italics after having pressed enter or accept.
In the case that with the simple gesture of using the Backspace key, “the one that deletes the character to the left of the word” the action in italics is deactivated and we can start writing the new word or phrase in Normal. Therefore the mouse pointer should not be used to deactivate.
Thank you very much. :star_struck:
@CésardlTG Excellent. I’ll test it out, today. That’s a nice workaround, if so. Cheers!
I can report @CésardlTG’s workaround helps. Using backspace to delete the previous text works to reset the rich text editor, instead of unchecking the italics icon (which often remains a persistent bug). This came up in another support ticket today, which is the reason for me adding this note for all.
