It ignores Italics property change from properties tab.
Hello - so far I do not see this:
Rhino.AddText "Text", array(0, 0, 0), 10
(Sorry, there was a 10 in there originally for the height)
https://mcneel.myjetbrains.com/youtrack/issue/RH-53387
Try:
It has to be created in Italics…
Windows 10 user: I have been seeing an error along these lines.
Often the text will show in italics when it should not. I switch off the italics button but it’s still in italics.
I re-open addtext and it’s still italics no matter what.
The font is not an “italics font” or anything like that, it is 100% an error in Rhino.
Edit: When it’s stuck in italics I can actually hit “bold” and get it to go back to normal (non bold, non italics) text.
Hello - can you please run SystemInfo in Rhino and post the results? What you’re describing was indeed a bug, as I recall but I believe it was fixed a while ago.
Here is the result of systeminfo:
Rhino 6 SR17 2019-8-23 (Rhino 6, 6.17.19235.15041, Git hash:master @ 06b69c5cc21d880aa793a5a7cfd454a66f6213bb)
License type: Commercial, build 2019-08-23
License details: Cloud Zoo. In use by: Shawn Kay ()
Windows 10.0 SR0.0 or greater (Physical RAM: 7.8Gb)
Non-hybrid graphics.
Primary display and OpenGL: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-19-2018 (M-D-Y). OpenGL Ver: 4.5.0 - Build 25.20.100.6446
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.5
Shading Language: 4.50 - Build 25.20.100.6446
Driver Date: 11-19-2018
Driver Version: 25.20.100.6446
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.17.19235.15041
Any update on this?
Still seeing this bug constantly.
Hi - Could you post the script that is causing this on your system? Also, which version of Rhino are you running now?
- Make a text with Rhinoscript in Italics
- Italics button in the properties will not work on this text object
It’s been like this since ver. 14 (that’s when I caught it the first time).
Thanks - I had checked with the python version and that seemed to work fine but, yes, I see this with the Rhinoscript version and have asked the developer to take another look.
RH-53387 is fixed in the latest Service Release Candidate
Well, now Rhino.TextObjectText resets text style…
Hi - could you please add a code snippet that I can run and then file?
Rhino.AddText "some text", Array(0, 0, 0), 12, "ISOCPEUR", 2, 0
Rhino.GetPoint
Rhino.TextObjectText Rhino.FirstObject, "new text"
I am still getting the same error, nothing has fixed it yet.
I am seeing it while using the standard _TextObject command.
I am having this problem too! Usually it fixes itself after several (very annoying) tries, but I’m now working with a file that seems to be cursed with every new text object in italics. I really hope they can fix this bug! Italic annotations can look really unprofessional
Hi Lia -
Are you using Python or Rhinoscript? Can you post the part of the script that is causing this?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Getting this issue right now, cant change out of italics
Please provide a 3dm file, run the Rhino SystemInfo command and copy-paste the result here.
