Bug: sticky italics problem
Once I select italics in the Text Object command, I cannot switch back to non-italics. Please see attached video. This seems to be a Windows only problem and works fine on Mac.
Rhino 8 SR10 2024-8-13 (Rhino 8, 8.10.24226.13001, Git hash:master @ c36ab43d576d4854b29b091b6b3a38e09decabf5)
License type: Educational Lab License, build 2024-08-13
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Unplugged [54% battery remaining] ~93 minutes left
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 4000 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.76
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 32.0.15.6076
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\mmagee\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Users\mmagee\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24226.13001
Hey Mike,
This ones on the bug list.
https://mcneel.myjetbrains.com/youtrack/issue/RH-79507/Text-Editing-Italic-does-not-stick
thanks @Trav!
its not just italic, its the old problem that tab stops are not working too, reported a lot over the last years.
this is really annoying!
This is still an issue with the latest Rhino 8 SR. We have a customer who brought this bug to our attention, do you know if there is any progress planned on this issue @Trav ?
This was my version that I discovered the bug:
Thanks guys.
Hey Jake, I don’t think so but I’m not very close to the subject on this one. I see from the YT its been found to be a WPF related issue but past that I don’t know much. Perhaps @Alain or @curtisw can provide more info about any solutions?
I’ve previously published workarounds for sticking italics in Text Objects and Text Blocks. See Rhino italicizing or bolding font even if I turn it off - #11 by jeremy5
HTH
Jeremy
