I need to export to OBJ for a client - can you suggest anything?
The OBJ export plugin is enabled
I tried it with a simple cube and that succeeded but that doesn’t help me - the client needs the file, not just a cube
Thanks for any help you can offer
Hello - I guess it would be best if you can post here or send us via tech@mcneel.com an example file that falis - the simpler the better. Please include a link back here in your comments, and also Copy/paste the results of the SystemInfo
command in Rhino.
I sent the file to tech@mcneel
I exported as geometry only and that worked but it makes it more difficult for my client because all geometry is now on one layer, default.
Interesting to note, the Rhino file that is created using geometry only is just under 10,000 kb but exporting as OBJ results in a 61,000 kb file
system info -
Rhino 6 SR34 2021-2-3 (Rhino 6, 6.34.21034.07001, Git hash:master @ 2fec8130f097ca52a8bc9f334c3ed4a5921c5e30)
License type: Commercial, build 2021-02-03
License details: Cloud Zoo. In use by: Alex ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: ALEX-PC
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1070 Ti (NVidia) Memory: 8GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.34.21034.7001
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Thea For Rhino (0ab51401-0ca2-45e3-94e0-46d77b129353)\2018.3.18.0\Thea_V2\TheaForRhino.rhp “Thea For Rhino”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.34.21034.7001
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\RealDrawings (9aaa3b93-9ea4-4425-b44e-8a8c4500c274)\1.0.7038.31206\RealDrawings.rhp “RealDrawings” 1.0.7038.31206
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.34.21034.7001
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.34.21034.7001
Yeah, obj is a text format and not terribly efficient in terms of file size. It also exports, optionally, more or less information -
To anyone else reading this thread - I disabled the Thea plugin as per Pascal’s suggestion and I was able to export as OBJ with no problem. I re-enabled the plugin and all is fine.
Thanks Pascal
I have the same issue, with a collada file. Please help. I have tried everything that I’ve read so far from multiple threads, but nothing seems to help. Please help.
