Hi, I’m using rhino 6 for mac and I can’t export any object in .obj format or any format too. I tried to unninstall and reinstall but I keep getting this error message whenever I export a file or object : “The writing plug-in failed”.
Hi - Could you try resetting your preferences to see if that helps?
If you have customized a lot, you might want to save your preferences first - see this document: https://wiki.mcneel.com/rhino/mac/resetprefs
I already did that reset and nothing changed, however I noticed that I can export some objects if I choose the “nurbs” option in the obj export dialogue options instead of “mesh”.
