Stp/Stl export the file writing plug-in failed
Hi there,
it’s a week I have this problem I couldn’t solve reading through the forum.
While attempting to export a step file this message pops up:
some points I have to precise:
  • doesn’t matter the object file;
  • I tried to repair the Rhino installation through the apposite function in the app manager;
  • The necessary plugins are loaded;
  • I will post here in the first comment the systeminfo result.
I really hope you can help me
systeminfo:
Rhino 7 SR12 2021-11-9 (Rhino 7, 7.12.21313.06341, Git hash:master @ 5590153808223b57a9f41516a969fd949aa81bff)
License type: Evaluation, build 2021-11-09
License details: Stand-Alone
Expires on: 2021-12-26
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-23-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 10-20-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.42
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-20-2021
Driver Version: 30.0.14.7242
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino6.rhp “Karamba3DLicense”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\export_STEP.rhp “STEP Export”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\export_STL.rhp “STL Export”
C:\Users\ercom\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hi -
Does it work when you save to your desktop or a different folder on the C: drive?
yes, in that case, it works… I suppose it has something to do with the NET framework but I’m not so sure
Hello- is are you writing a second file of the same name, that is, replacing a previous version, with your export?
Hi Pascal, in this case I was replacing an existing file but if I try to make a new file the same error pops up
So, some formats write a temp file - if your target is a synced folder like DropBox or GoogleDrive, then this file needs to be replaced or removed, potentially at the same moment it is being synced - that is my guess as to what is happening - are you saving to a synced folder?
Yes, it’s a folder inside my office NAS that is synced with a folder on my PC… I tried to pause the synchronization but didn’t work
Do you have any suggestion on how to solve this problem?
@tim - do you have an idea? Is this related to writing a temp file, for stl?
A newer build allows writing of the stp temp file to be skipped and works to fix the users problems saving to stp & stl.
