Textures turning them 90 degrees, texture gone
Hello, I find it very strange that I haven’t come across this issue anywhere yet. But are there others experiencing problems after an update?
You select a square, apply a texture to it, and then decide to rotate it 90 degrees. So, in the interface, you open the texture and rotate it 90 degrees. However, instead of seeing the texture, you only get a base color.
Is anyone else having this issue?
Hi @saam
Please post a file showing the problem and the full result of running the SystemInfo command in Rhino! Initial test here shows no problems:
HTH, Jakob
