I am new to Rhino. Searching through the forums, I believe a similar issue to this has been discussed before but I can’t figure out how to fix my model. The woodgrain texture I applied is correct using a rendered viewport but when I select the “render” command, the texture is rotated 90 degrees as shown in the screenshot below. How do I fix this?
See attached Rhino 8 model and system info file below.
marble_coffee_table.3dm (4.3 MB)
system_info.txt (2.3 KB)
