I’ve had this issue pop up a few times now, and I finally have a good example to show it. In this model, I’m trying to create room covered in graphics and tv monitors all showing one image. I’m trying to simulate it here for a mockup, which should be an easy task for a shared spherical mapping, but at least one surface is misbehaving at all times.
It seems as any object nearly tangent to the North and South poles of a sphere or nearly perpendicular to the axis of a cylindrical map (capped or not) get an odd herringbone distortion of the map.
Below are an array of screen captures of various settings.
As a separate issue, I noticed a problem with cylindrical mapping that may also affect other modes. It seems as though there is a point on the cylinder that almost directs the object it points to to condense the mapping to fit to the width of the object. I’ve drawn a line on the top view to hopefully help illustrate. I had the mapping set to repeat three times (roughly Pi) so there’s less distortion, but when the cylinder mapping widget is rotated, the surfaces that are along that line actually repeat three times on that surface.
Things I’ve tried:
Different drivers for my Quadro P2000, 391.33, 391.74, 377.11 (no change)
Turning on/off GPU tessellation (no change)
RefreshAlltextures (no change)
RefreshShade (no change)
Extracting Render Meshes (similar problems, though not necessarily the same)
System Info:
Rhino 6 SR6 2018-6-26 (Rhino 6, 6.6.18177.16151, Git hash:master @ abeff9e9af62a0e02a9eb52efa77e179a682f2c7)
Licence type: Commercial, build 2018-06-26
License details: Cloud Zoo. In use by: Michael (BUiLT Design)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: WINDOWS-8ESRLPN
Quadro P2000/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 391.33)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-22-2018
Driver Version: 23.21.13.9133
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.6.18177.16151
