So, I was doing some texture mapping and I found out a weird occurrence, the texture flips between rendered and raytraced.
I recorded and placed the file on the attachment below.
Hello - I am not seeing that here, but your image is not included in the uploaded file., I used my own image.
Sorry, I thought the texture would be attached inside the 3dm file.
here you go.
Telaquemudadeorientaçãonorender.3dm (335.6 KB)
@altamiro.aj the file was created with Rhino 6.13. You should update as there have been 21 service releases since.
That fixed it, thanks!
