After reporting my texture problems since nearly a year I was hoping for some fixtures in the Rhino 7 version, but apparently it becomes worse with every new update.
What’s new is that textures are displayed wrong in ray tracing view but correct in rendered view, or vice versa like in the example below:
Rendered view (in the small picture to the left you see the original)
With @Jussi_Aaltonen we have been looking quite a lot at your problematic models, but I was under the impression we managed to fix at least most of them.
For the pipes that are marked wrong in the Raytraced view I believe I had given some instructions on how to do the texture mapping better in such a way that they are correct in both Rendered and Raytraced view.
Did you try that setup?
thank you for your reply. My release is Version 7 SR8 (7.8.21196.5001, 2021-07-15)
I’ve reported part of the problem in May here and uploaded a file on your request, however did not receive an answer since. I might have missed it somehow, but at least in that thread there was no reply. If you or Jussi have a solution/instruction how to get around this, I’d be most grateful to follow.
Hmm, I have the distinct memory typing some instructions regarding your texture mapping usage, but I can’t find the post anywhere. I must have not sent it at some point. I’ll re-type the findings I had made at the time and post them this time properly.
What’s new to the problem I reported in May is that since one of the last updates now also the uppermost pipe is displayed wrong in rendered view. No changes were made to this pipe meanwhile, actually it’s a generic material with a slightly weathered white texture used throughout the project for thousands of objects.
Ah yes. I was supposed to type them instructions. I don’t have a dog, so I have only myself to blame for not typing them in again and send them.
The thing that stood out most to me was your use of texture mapping. For instance with the tubes you use Cylindrical mapping, which in itself is a good thing. Except in some cases you have the cylindrical mapping placed such a way that essentially the cylinder and your tube are at a 90°.
Also, you’re using the Ray projection, which doesn’t really work in Raytraced/Rhino Render.
Orienting the texture mapping properly, more closely matching the geometry you’re mapping on, and uisng closest point projection should yield you results that work for both Rendered mode and Raytraced/Rhino Render.
In the shot below I made a copy of the original vertical pipe, moved that to the back, and redid the texture mapping on the one in the foreground. It has now a cylindrical mapping that is closer to what the geometry is, and closest point is used. You can see that the Rendered and Raytraced viewports now agree.
Addendum: I forgot to say that since your textures are only simple lines you can do your pipes even with simple planar mapping. If you then want to optimize the texture you could make it just one pixel high or wide as well, since the pixels just repeat in that direction
thanks a lot for your extensive and helpful reply!
I think this is because I applied the texture to the whole, initially horizontal cylinder to get the correct proportions and then split it and rotated the vertical portion upward. I was not aware that this is a forbidden technique.
For the horizontal part, switching from Ray to Single Point projection does the trick. However I have to confess that I’m not sure how you fixed the vertical portion. Did you delete the original mapping and then assigned a cylindrical mapping from the scratch and rotated the UVW to 0,0,-90 ?
And a version with just the simple planar mapping,ever so slightly faster (simpler math)
Wow, thanks a lot! Did not know this would work.
Best greetings and thanks!
Cyana
Ah, I forgot one step. I indeed deleted the original mapping, created a new cylindrical mapping. But the easiest to control this was to have a duplicate of the material, and then rotate the texture.
delete original mapping
add new cylindrical mapping
duplicate material
assign duplicated material to pipe
select duplicated material
select texture in duplicated material
set rotation in texture mapping section, I believe it was set to 270°
In the end I think using the planar mapping in your case is going to be easier for these pipes. And as said you could save a few bytes by making these simple textures just the one pixel high (or wide, I forget which way around the stripes go)
again, thanks a lot for your helpful advice! I’ve now reduced the width of the textures to 1 pixel, and replaced the material. Is there an advantage of planar over cylindrical mapping? - the new texture works perfect with the original cylindrical mapping, too.
