I can not seem to get the display to work
I have it set to shaded. Does anyone have any suggestions
thanks,
thanks,
Shaded does not show textures or materials by default. Use Rendered mode instead.
Hello- set white point to something between zero and one but not zero…
When I set the white point higher then 0 then it projects the
white area of the texture off the surface that i applied the texture to
and it still does not show the black and white texture in render mode
Hello- for the texture to show as a rendered texture, use a material with that texture - that is not the same as displacement.
