Is there a new setting off by default in v6? Thank you!
I don’t believe textures have ever been visible in Shaded mode by default. Have you changed the default display settings of Shaded mode in V5?
Rendered mode, on the other hand, shows textures.
-David
What? Textures work in Shaded View here. V5
Just choose Rendering Material in Color & Material Usage
That would be a modified version of the default Shaded
mode - hence David’s question.
FWIW, changing the default RH6 Shaded
mode as per @arail’s comments makes textures visible here on my system. @hannesgrebin, is that not something you are seeing?
