TextObject command not showing typing column on windows rhino7
Hi guys,
Here’s screenshot of my textobject command window, there’s no where to type in text, my rhino7 is up to date. Not sure what’s going on. Anyone can help?
If you grab the lower edge of the dialog and pull it downward, does the box show up? I have reported this problem with a few other text entry boxes…
Do you have DPI scaling enabled in windows? It seems that your UI text has been scaled 250%
Definitely possible if one is on a laptop with a 4K screen. Mine is at 225%.
OOoH, it showed up, ok, thank you so much, i guess it’s my windows setting, I have a laptop and the screen probably too small.
OK, looks like this might be part of the same bug I posted here:
https://mcneel.myjetbrains.com/youtrack/issue/RH-67935
I added a comment to the bugtrack item to reference this thread.
